All, need some help here, do Hope make both 183 and 185 floating saw rotors, cant seem to find the answer by trawling through CRC etc
I am aware they make 200 / 180 / 160 / 140 in the older M4 mono minis but, they also appear to make 183 and some people on here list 185's for sale, are 183 / 185's the same and people getting mixed up ?
I have 183's on my tech X2's if that helps - I think it's more the adapter that maters and that it's for the right rotor.
I agree but again, is there a 183 and 185 mount or are they one in the same ?
i have 183,s on mine (thats the front) rotar... on the rear i have 160...its what came with the bike..
There are now only 183mm mounts available. Hope will still make a 180mm floating rotor if asked to though.
You used to be able get 185mm and 205mm rotors, then 3 years ago it changed to 160,180 and 203 and now it's 160/183/203.
The answer to your question is - in the open marketplace - no, only 183mm floating rotors.
If you're planning to use it with an avid calliper, just use a hope 183mm mount. It works fine.
Wiggle have a good selection of floating saw tooth in including 180mm
http://www.wiggle.co.uk/p/cycle/7/Hope_Floating_Rotor/5360029666/
