Hi first post and all that so go easy,
I went to fit some E3 brakes today but can't get them to match up with my I-Spec B shifter. Could someone plese post a link or picture of the two bolted up together. I can see whats ment to happen but unsure if I need more bits or a different bolt.
Posted : 18/10/2015 9:06 pm
You need the little square nut, it drops down inside the shifter and then you bolt the shifter to that.
Posted : 18/10/2015 11:11 pm
Thanks so much will get one today from the local hardwere shop
Posted : 19/10/2015 6:57 am
Square but? Do you have a PIC?
Posted : 19/10/2015 7:36 am
Guessing it like the ones in this picture
http://www.chainreactioncycles.com/hope-tech-3-matchmaker-clamp/rp-prod113073
Posted : 19/10/2015 2:11 pm
Yes those are the nuts, you should have some with the shifters, if they're new.
Posted : 19/10/2015 6:25 pm
