Hope compatibility?
[Closed] Hope compatibility?
Hi,
I have a well worn set of Hope Mini calipers that need replacing. Could anyone tell me if Hope X2 2009 calipers will be compatible with my old Mini levers and would these be a good upgrade from the Mini?
Posted : 27/02/2011 1:47 am
Yes and not sure.
I run a similar set up.
Posted : 27/02/2011 1:54 am
They'll work fine, but you may need to space the caliper out a touch, as original Mini's ran a slightly larger disc.
Posted : 27/02/2011 9:06 am
Thanks guys. I realise that the fixing mounts will differ, it was really more to do with the leaver hydraulic capacity and if for some reason the hydraulic system and operation would be different/not compatible - any more feedback would be appreciated before I splash the cash!
Posted : 27/02/2011 10:56 am
