Hope BB GXP convert...
[Closed] Hope BB GXP converters - can they be used with other BB's?
Got a bike with a PF Shimano BB, a pair of the Hope GXP BB convertors and a spare SRAM crankset.
Is there anything 'special' about Hope bearings that allows this (or Shimano ones that prevent it)?
HopeTech BB diagram
Posted : 27/02/2019 10:43 am
I'd imagine the bearing width would be key consideration. Since you have to press them in then give it a go. If they don't fit or the is friction then it's a no, otherwise I'd try them with cranks.
Posted : 27/02/2019 12:07 pm
Hope bearings have an ID of 24mm & make direct contact with the crank axle.
Shimano bearings have an ID of 25mm & use a plastic tophat spacer between the bearings & the crank axle. The tophat might mess things up. I guess the only way to find out is to try it.
Posted : 27/02/2019 12:19 pm
I'll give it a go, if my frame explodes I'll report back.
Posted : 27/02/2019 12:24 pm
I'd say no, as the placky tophat nobbles things.
Posted : 27/02/2019 1:19 pm
they don't.
The top hat thing wasn't much of an issue but there's so much plastic around the back of the bearing that there's no access to fit the spacer on the there.
Posted : 27/02/2019 2:32 pm
 5lab
the sram clamping mechanism works by clamping a single bb cup and applying any sideways force (in either direction) to that cup. I would suggest a bb cup that hasn't been designed for that force will fail fairly quickly. Surely if you're relying on clamping the top hat (plus an adapter) there's nothing to stop it simply moving outwards away from the frame?
Posted : 27/02/2019 2:50 pm
