Hope 180 floating r...
[Closed] Hope 180 floating rotor?
I have XTR brakes and calipers and wanted to increase the front 160 disk.
I ordered a 20mm+ adapter and had a Hope floating rotor spare but the rotor is a 183mm and doesn't fit. Do you get floating 180s?
Posted : 28/07/2009 11:15 am
yes you can, but i have ran 183's without issues its only 1.5mm different and am supprised if the outer rubs on the caliper? To get some of the 1.5mm back make sure you hold the caliper up/out so its as far away from the hub centre as possible before nipping the screws up, the slack around the bolts will give you some.
Posted : 28/07/2009 11:21 am
the old style of floating rotor was a 180 IIRC..
here
[url= http://www.cyclesportsuk.co.uk/product_info.php?products_id=3668 ]http://www.cyclesportsuk.co.uk/product_info.php?products_id=3668[/url]
180 rotors the older (none buzz saw) versions
Posted : 28/07/2009 11:22 am
Doh, didn't think to look beyond CR. I've found them here too.
http://www.wiggle.co.uk/p/cycle/7/Hope_Floating_Rotor/5360029666/
Posted : 28/07/2009 11:23 am
I've got a spare 180 and 160 floating sat in the garage doing nothing. Blue middles. Make me an offer!
Posted : 28/07/2009 11:58 am
Unfortunately the 1.5mm does rub hard on the XTR 960 calipers. Look on classifieds soon for brand new 183mm floating rotor (RED)
Posted : 28/07/2009 11:59 am
 D0NK
I've got a 180 floating but the rivets holding the disc to the ali spider hit the caliper on my XT 760 brakes (same caliper as xtr 960 i think) so I'd stick with a standard rotor if I were you - unless you can try before you buy ๐Ÿ™‚
Posted : 28/07/2009 12:03 pm
Just put an extra washer or 2 between the caliper and the mount. That'll give you the extra 1.5mm. It's what I do.
Posted : 28/07/2009 12:22 pm
What glenh just said. Ain't rocket science! ๐Ÿ˜‰
Posted : 28/07/2009 12:25 pm
 D0NK
Assuming it's a post mount caliper not an IS one.
Posted : 28/07/2009 1:56 pm
IS to IS on this occasion
Posted : 28/07/2009 1:57 pm
XTR IS caliper on the front? Sounds unusual, however, I beg your pardon.
Posted : 28/07/2009 2:00 pm
ChatsworthMusters - YGM re those rotors.
Sorry to hijack the thread briefly.
Posted : 28/07/2009 2:10 pm
paulio, I'm busy talking to another guy, presumably OP, but if that falls through I'll get back to you.
Posted : 28/07/2009 2:12 pm
Ok no worries.
Posted : 28/07/2009 2:19 pm
