Hollowtech 2 non dr...
[Closed] Hollowtech 2 non drive side washer... Is It needed ??
Just bought some used ht2 cranks and noticed the non drive side crank arm washer is missing.
Hopefully thus should link to a pic.....
https://www.bing.com/images/search?q=shimano+hollow+tech+ii+diagram&view=detailv2&&id=D68AC01B4AABD1712EE9BB8F0854DFDB539565E6&selectedIndex=3&ccid=Frz1A6V5&simid=608035038044684775&thid=OIP.M16bcf503a5798ea42b4629930993e5cdo0&ajaxhist=0
Its not the bit circled I am on about but the circle washer piece.
As I'm going to be running a wheels mfg conversion bottom bracket I'm not sure if I need it or not ?
What do you reckon ?
Cheers.
Steve.
Posted : 28/09/2016 3:53 pm
You probably don't need it, but it wont cause any harm either way.
I've had one missing for a while and no kittens were killed.
Posted : 28/09/2016 3:56 pm
are you sure it's not in there ? they usually become embedded within the crank - look up the open groove where the tab goes and see if there is a solid bit (washer) at back...
Not really no. It's just a seal I think. I've seen kids without it.
Yep deffo not there.
I wouldn't normally ask but as I'm having to run a pf30 conversion bottom bracket I'm not sure if it is important or not.
Posted : 28/09/2016 3:58 pm
I actively ditched them from my road bikes as I found that my Stages crank made creaking noises when it was in place. Have done thousands of kilometers like that now.
Posted : 28/09/2016 4:18 pm
Cool so it sounds like its not really needed then.
Posted : 28/09/2016 4:20 pm
Yeah just seals crank arm with BB, you'll be fine without it, if your worried about it I reckon you could just fit a rubber o ring.
Posted : 28/09/2016 6:17 pm
