high speed compress...
[Closed] high speed compression dial frozen (coil Lyrik)
 hora
Left the dial at full off/anti clockwise and came to use/its frozen/stuck-stiff.
The motion control unit is bawked isn't it? Two week old fork.
Posted : 29/08/2011 4:59 pm
This won't help but mines frozen too! They came like that (I bought them second hand a couple of years old from a mate so knew about it). I've been riding on mine anyway and they still feel lovely!
Posted : 29/08/2011 5:02 pm
 hora
He sold them to you like that?
My fear is its a leak in the Moco unit and it means a new units needed. Can I ask for them collected as I don't fancy paying postage for a warranty fault 🙁
Posted : 29/08/2011 5:06 pm
Yeah he did, he said he'd never actually bothered playing with it and gave me serious mates rates so I don't mind it! As I say though the fork still rides fine and feels ace, guess it must have stuck in a good position for me! I've had the unit out a few times and can't work out what's wrong so I'm saving up to send them to Loco/tf tuned when I get the money!
Can understand it being crap if they're new forks though!
Posted : 29/08/2011 5:08 pm
It'll just have some grit in it.
Posted : 29/08/2011 5:09 pm
just open it up, take the moco out and see if you can free it manually. Its not particularly complex bit of kit. IIRC the gate unscrews in a clockwise direction...
Posted : 29/08/2011 5:10 pm
Nope, should've bought them from your LBS 😉
Do you actually want to use the adjuster? Or just having a play?
Posted : 29/08/2011 5:32 pm
 hora
A play really
Posted : 29/08/2011 5:35 pm
My Rev's u-turn knob stuck fast within the first month, lube & lots of twisting (once I got it to start moving) over came the grit that had got into it & it's been fine since
Posted : 29/08/2011 5:36 pm
Just force it a bit. This is the advice I got from a former pro-team suspension tech. I gibbered a bit, got some mole grips, then turned the dial. It worked like a charm.
That was for the wee silver dial on top, can't remember if that's the low or high speed? Mine has subsequently fallen off and got lost (not related, I don't think)!
Posted : 29/08/2011 6:01 pm
Do you mean MoCo or MiCo?
what stoner said, take it off the fork give it a clean and a fiddle theres not a lot to it. if its Mico and has still got the floodgate take it off (effectively turns it onto the new MiCo DH)
http://www.singletrackworld.com/forum/topic/older-lyriktotem-compression-damper-modification
Posted : 29/08/2011 6:28 pm
If you do send them back then don't use parcel force to send them. Use Parcel Monkey as it's £1 per £100 for insurance or someone similar who offers the cheap courier deals.
Posted : 29/08/2011 6:29 pm
 hora
Could be a goodtime to do the mod. Cheers as my utirn spring/topcap also comes this week 🙂
Posted : 29/08/2011 6:43 pm
