Hex screw help!?
[Closed] Hex screw help!?
I've managed to round out the 2mm hex head screw on a derailleur hanger. Try as I might I don't seem to be able to unscrew/remove the screw. Any ideas/pragmatic suggestions from the Singltrack hive?
Not sure why they use 2mm hex fittings for this or any other location on bikes!!
Posted : 04/03/2017 4:58 pm
Cheap torx bit.
Hammer.
Posted : 04/03/2017 4:59 pm
Forgot to mention that the hex head is countersunk so unable to saw across to use flat bladed screwdriver, etc.!
When you say "hammer" do you mean hammer drill?
Posted : 04/03/2017 5:06 pm
Hammer the cheap disposable torx bit into the mangled mess and undo.
Socket ratchet will allow you to gently add the force to undo.
Posted : 04/03/2017 5:19 pm
As above, also try applying heat if you have no luck.
Posted : 04/03/2017 5:23 pm
Thanks for the replies and advice. Panic over; I used the hex key from my trusty old Leatherman and I managed to shift it! New screws will be ordered!
Many thanks all.
Posted : 04/03/2017 5:43 pm
