Hi.
I am looking for some advice regarding spoke lengths, having had a look online and used various calculators I think i have the correct figure but would like some confirmation.
Here is the info, I would really appreciate it if someone could help with this or even point me in the direction of a company who could (I will happily pay!),
Hubs - Pro 4 Straight pull
Rim ERD - 540.5mm
Asymmetric rim so 3mm off set
Spokes - CX Ray aero
The remaining info is on the graph below:
[IMG]
[/IMG]
I came out with 271 F & 270mm R.
Does this look right?
Thanks in advance
How many spokes and what pattern ?
That would also help!
32H & 3 cross pattern
By my calcs using DT 12mm nipples (which should be the same as the ones that come with your CX Rays I think) the you get 267 all round. Calcs here:
Edit: FYI you're calcs are based on j bend not SP hubs hence the difference.
Thanks for the reply Ben and screenshot, does that also actor in the asymmetric rims? I presume they will make a difference compare to normal?
Yes, you'll notice that the flange distances are +/-3mm from what they actually are to account for the asym rim. You should check my numbers against this to double check:
Wheelpro agrees:
EDIT OK all fixed 🙂 268s all round.
Is that ERD from the manufacturer or measured? Double check it!
