Help..help...help.....
[Closed] Help..help...help..siezed Rebas
My maxle on my Rebas is proper proper siezed. as in turn 1/4 and then won't go any futher.
Bloody new fangled maxle things, year of QR use and no problems, any ideas before I send them back?
Posted : 13/05/2010 9:52 pm
Unscrew the wedge completely - see if that helps. Unscrew the axle as much as possible then hit it with a rubber mallet? Usually if they seize its on the central spacer in the wheel so will unscrew but then won't come out of the wheels
Is this brand new? I fail to see how it could unscrew a 1/4 turn then stick. Something odd for sure
Posted : 13/05/2010 10:08 pm
Well Mr. TJ it looks like you spot on. The cup is stuck in the fork at the QR side so the maxle turns with a bit of force but all it's doing is flexing the forks apart.
Rubber hammer didn't budge it.
Any other ideas? bit scared of using a bigger hammer ๐Ÿ˜
Posted : 14/05/2010 6:58 am
Bit late now, but you're supposed to grease them lightly to prevent this happening.
I've done the same thing though, a meeting with my friend Mr Mallet (not Timmy) fixed it
Posted : 14/05/2010 7:00 am
