Help with KSi900 se...
[Closed] Help with KSi900 seatpost - wont stay down!
It worked a couple of days ago, but it now does not stay down when it is lowered and just comes back up again.
I think I slightly loosened and re tightened the red collar when pulling it out to have a look at it, if that is anything to do with it.
All help greatly appreciated!
Dave
Posted : 21/02/2011 4:28 pm
Have you tried cleaning around the lever? Might be some muck holding the lever up?
Posted : 21/02/2011 5:17 pm
Yep, check all points of the cable movement first of all
Posted : 21/02/2011 5:21 pm
When you loosened the red collar you increased the rebound setting. You need to reset it -
Use the link below - page 4 for instructions
Posted : 21/02/2011 5:28 pm
I will give them all a go, pretty sure the lever is clean as it has just been returned from being fixed, so reckon it might be the rebound thing.
Many thanks
Dave
Posted : 21/02/2011 5:41 pm
Too much tension on the barrel adjuster on the remote release. Screw it in a turn or so.
Posted : 21/02/2011 8:21 pm
If not send back mine fell apart during the mega and came back all shiney and reassembled. (Dont take it completely apart)
Posted : 21/02/2011 8:28 pm
