Hi can anyone tell me what length spokes i need the rims are stans crest 29er & the hubs are hope pro 2 & they will be done the std 3x cheers.
try the wheel pro or DT spoke calculator but I'd guess around 294mm
Just to make it easier how many spokes?
Hi 32.
Anyone
Did you try the spoke calculators? I'd be interested to see how far off the 294 I suggested, it actually is.
[url= http://www.notubes.com/product_info.php/cPath/685/products_id/497 ]Stans website[/url] has the ERD of the rim. [url= http://www.hopetech.com/database/2010%20HUB%20offset%20and%20pcd.pdf ]Hope's hub dimension chart[/url] (current hubs) lists the other dimensions you need. Chuck it into [url= http://www.dtswiss.ch/SpokesCalc/Welcome.aspx?language=en ]DT Swiss's spoke calculator[/url] and Bob is your mother's brother.
Cheers shedfull for the links its easy when you know,onzadog for the front & rear they are between 292.2-293.6 so i think 294 is spot on.
While this thread is here, can anyone help me out with what spoke/nipple I need for my Bontrager Rhythm front wheel? It's the one that comes standard on an 09 Trek Remedy 7. They have offset rims fwiw.
