Help: Road brake ca...
[Closed] Help: Road brake caliper not reaching down to braking surface on rim,
Need some dark side help.
Had a 105 brake rear brake caliper sitting in my bike box and put it on a bike last night, but for the life of me I could not get the brake blocks to sit over the braking surface of the rim, they just don’t reach that far down. I have slid the brake blocks down in the slots on the brakes as low as they go and still they are about 3-4mm to high and basically grip onto the top of the rim and the bottom of the tyre.
Anyone have and bright ideas? Have I done something wrong?
Please help!!!!!
Dave
Posted : 10/08/2011 8:56 am
Road brake calipers have different 'drops' I believe
Posted : 10/08/2011 8:57 am
you need deep drop (58mm ??) road brake - i.e. the ones they use for winter bikes /bikes with mudguards
Posted : 10/08/2011 8:59 am
You'll be needing some 57mm drop brakes. Sounds like you are putting standard drop brakes onto a winter frame.
Posted : 10/08/2011 9:00 am
that would make sense as it is an old steel planet x frame with mudguard and pannier rack mounts. that is a pain - i was suppose to build it and take it to france on saturday. could be some sprinting aroudn the LBS tonight I feel!
thank you all
Dave
Posted : 10/08/2011 9:02 am
Can't you fabricate something to drop the caliper a bit?
Posted : 10/08/2011 9:04 am
You'll find some easilly. If you want to play safe I THINK that Tiagras are 57mm only.
I bought a frame from Fleabay that turned out to be a cut and shut. Shallow brake for the front, deep for the back.
very tricky as the bolt goes through the frame and the pivot of the caliper.
Posted : 10/08/2011 9:05 am
I got some decent 57mm Shimano drops from Ribble earlier this year. If you want to spend less, then Tektro do some reasonable budget ones.
Posted : 10/08/2011 9:07 am
You need something like this:
http://www.chainreactioncycles.com/Models.aspx?ModelID=27807
Posted : 10/08/2011 9:08 am
[url= http://www.ribblecycles.co.uk/sp/road-track-bike/Brakes-Road-Shimano-R450-57mm-Brakes/SHIMBRAR340000000000 ]These[/url] might be worth a look too
Posted : 10/08/2011 9:09 am
thanks all - will go see what i can get.
cheers
Dave
Posted : 10/08/2011 9:24 am
My Ribble winter bike as supplied needs a deep drop front, but will take a shallow drop rear - handy given that mrs aracer's Tifosi needs a deep drop rear but works with a shallow drop front, hence I only needed to buy one pair of deep drops between them (and could re-use a pair from my parts bin for the other end).
Posted : 10/08/2011 10:00 am
