I am going to change the setup on my 2005 Heckler to make it mini d/h bike.
I am looking at buying a Shimano Saint Rear Mech to use on my 2005 Santa Cruz Heckler. I am also going to change the front ring setup to double rings (using a 22T inner ring and 36T mid/outer ring) using an e thirteen DRS chain device and bash so I have chosen a shimano saint short cage mech as i want a short cage one.
I have Shimano XT gear shifters.
I currently have a 9 speed Shimano XT 11 - 34T rear cassette but was thinking of changing it to a 9 speed Shimano XT 11 - 32T cassette
Will this rear mech work with this setup?
I noticed a comment in an advert for the saint rear mech;
"For double ring use with a total capacity of 31 tooth, or 37 tooth with mode converter in"
and i wasn't sure what it meant!
Also would the e thirteen drs setup size "up to 36T" be big enough with a 36T ring or should it be a bit bigger than the largest ring
thanks
my 34t raceface bash ring is about 1mm over the various 36t rings ive used. i have had a fair few strikes on it with no probs so far, as for the rest of your Q's,,,,,,,,,,,, fuknose ?
Your e13 drs will be fine, it's up to and including a 36t middle ring.
If your using your bike as a mini dh bike then i doubt you'll be in your 32t top gear anyway so wouldn't worry too much about the mech being suitable for that - it'll be fine on the rest of the spread just a bit stretched on the top one.
Oh and as for the mode converter on the saint mech - christ knows what that means!
