Help required with ...
[Closed] Help required with DHX RC4 set up,
Ive recently fitted a 2014 DHX RC4 to a speicalized status, Ive got the sag set ok, ive got the rebound set ok, and im still playing with the LSC and HSC, however the thing I dont have a clue about is the Air Assist adjustments.
Currently got pressure set around the middle of the 125-200 psi range and the big blue knob set to minimum,(as it was when received) I would turn this knob and start with it in the middle but there dosnt appear to be a middle? where would be a good starting point with this?
Posted : 16/09/2013 7:49 pm
Best to set the boost valve dial to completely off, IMO, then play with it to see what happens.
Posted : 16/09/2013 7:56 pm
