Hi
Trying to remove the bb from my sons kink bmx. It is a mid 19mm bb and a 3 piece crankset. Got the cranks off but cant suss how to remove the spindle?
Drive side has a raised rim to the sindle in front of the chainring, non drive side has a threaded outer section of spindle just behind the 8 splines. Any clues please? Do i need to undo something from the external threads on the non drive side ??
Thanks
Posted : 10/06/2018 5:35 pm
Leave the drive side crank arm attached to the spindle and pull the spindle out through the BB, by pulling on the drive side crank arm.
Posted : 10/06/2018 5:49 pm
Cheers Chipsngravy! Did just that! Although there was a large threaded washer that had to come off first.
Posted : 13/06/2018 3:02 pm
