Help! Quick-release...
[Closed] Help! Quick-release lever has disappeared!
All there is left is a ribbed bit sticking out a few mm, a bit like the end of a hex key. This needs to be rotated 180 degrees to release the wheel but I can't get enough purchase with pliers. Is there a secret way of getting the wheel off in this situation?
Posted : 21/11/2012 10:05 am
Undo the knurled nut at the other end of the axle? Pliers should be able to grip it.
Posted : 21/11/2012 10:06 am
No, the plastic nut thing the other side is just going round and round without undoing
Posted : 21/11/2012 10:13 am
pics please?
Posted : 21/11/2012 10:15 am
Mole grips will be the right tool for this job (for once).
Posted : 21/11/2012 10:19 am
Mole grips - if you don't have a pair already it's time to buy one.
Posted : 21/11/2012 10:20 am
Some old ones take a torx key.
Posted : 21/11/2012 10:28 am
Sorry, you'll have to manage on your own. He's busy fretting about his Passat/trees etc ๐Ÿ™‚
Posted : 21/11/2012 10:30 am
Just ride it with disc brakes. It'll fall out and you'll die, you know!
Posted : 21/11/2012 10:31 am
Can't get molegrips to grip either...
[img][img]
Posted : 21/11/2012 10:36 am
if the nut on t'other en is spinning, the axle's turning. Make sure that the broken end is held still, too.
Posted : 21/11/2012 10:43 am
If it is cup and cone you might be able to use a cone spanner to tighten the bearings a tiny bit, which will loosen the QR. Failing that I'd probably cut off the nut end and drill out the thread.
Posted : 21/11/2012 10:49 am
Done it! Found some smaller molegrips and applied superhuman strength.
Thanks for all your advice!!
Posted : 21/11/2012 11:09 am
