Hi guys I have been trying for a few days to get pedal off and which will just not budged. I have tried wd40 but still no go does anyone have a magic solution.
Thanks
Are you sure you're turning it the correct way? (I'm not taking the p*ss, I've got this wrong in the (distant) past 😳 )
Go to your Local Bike Shop and get them to use their really long pedal spanner on it.
Then buy something, or take them some cake.
Support your LBS.
if that fails buy some Plusgas. it seems to work on the most corroded shiz.
Left pedal thread is "wrong".
Otherwise a search of this forum will get (very) extensive suggestions.
decent length pedal spanner (my Tacx one is ace) and turn it the right way is the answer
Go to your Local Bike Shop and get them to use their really long pedal spanner on it.Then buy something, or take them some cake.
Support your LBS.
Or perhaps pay for them for doing the job 🙄
1. Are you sure you are turning it the correct way?
2. Pour kettle of boiling water over it?
3. Detach and crank and place in freezer and then pour kettle of boiling water over it?
4. [img]
[/img]
yeah get some plusgas or other penetrating fluid
Thanks everyone for the help and yes have been trying the correct way. I will try some plus gas see how works - fingers crossed.
geoffj
THIEF !!
Take crank off bike.
Clamp in the biggest ffin vice you can get access to.
Strong spanner and 1 metre tommy bar.
Blow torch crank and...
...give it some!!!
