As I had to cut the seized pin out of my titus I need the 2 washers that sit n the swing arm.
They are 16mm internal and 20mm external by about 1mm.
I'm stuck so before I go playing on a mates lathe any pointers?
Posted : 21/08/2015 8:38 pm
Anyone I'm a bit stuck
Posted : 21/08/2015 10:01 pm
Easiest thing would be to find a washer with a 20mm external, readily available, then drill a hole in it. Step drill is probably best for the hole.
Posted : 21/08/2015 10:29 pm
Hi Nick,
That's been my other thought. I found some shim washers on fleabay.
You just would think it was that hard...
Posted : 22/08/2015 8:25 am
Fettled didn't have a drill big enough but a mates got a baby model makers lathe so bored it out.
Posted : 23/08/2015 10:00 pm
