Child friend has a Magura Durin SL with the Albert SL damper. Its a non internally serviceable and has a hydraulic lock that can be solved for a couple of cycles with a drain/bleed but then its locked again in use.
AFAIK the (pre-TS8) Albert SL, Albert Select and DLO dampers all fit but I cant find anything out there to replace it.
I once foundย a german ebay parts fork when i was looking for the deformed foam elastomers (but I fixed these using boiling water and wife's best cookware) but I've seen no parts source for this generation of forks since.
anything of use from here?
https://www.axevotech.eu/en/ACCESSORIES-SPARE-PARTS/MAGURA
If the damper is not officially service but now broken, perhaps an option to try an unofficial repair?
Unfortunately nothing there, but thanks for the suggestion.
Normally I'd not be shy about taking the damper apart but the Albert SL is mechanically/crimp fixed so theres no bolts holding it together and would need to be cut open like a can of beans.
Last resort would likely be drilling a relief hole into the top of it to bypass the shim stack.. but I also don't know what it looks like inside as damper assembly diagrams don't seem to exist like for fox etc
Kids deserve good bikes
Absolutely!
the fork was superb before a hot stint in a black van on a 30+ day. It'll still be great if I can fix it.
I don't think there's anything better though to be fair in 26 that's as light and stiff as the Durin. But yes, having aย working fork is more important.
