Help me fix my 12sp...
[Closed] Help me fix my 12sp SLX chainring
Felt an odd flexing in my drivetrain today, turns out 4 of the 8 bolts holding the chainring to the spider of my SLX m7100 12sp set up are missing and a 5th is loose.
I have a security T15 torx bit somewhere (looks the right size) but the bolts look like they are non-standard. Has anybody manged to replace them? They are meant to be fixed and non-serviceable but looks like shimano screwed up here.
Over 2 years old so can't claim on warranty but frustrating as otherwise it is fine.
Cheers,
S
Posted : 07/05/2022 10:40 pm
Interesting. I had the same thing this week. Well, in that the 2 bolts on 1 of my spider arms have come loose. Also M7100.
I can't help you with finding a replacement bolt but I can share in the frustration with their use of security torx (why? How is that helpful halfway through a bike ride?) and thank you for the reminder that I needed to nip mine up before I ride again tomorrow!
Posted : 07/05/2022 10:59 pm
They def don’t look to be sold as a spare part as they aren’t listed on the exploded diagram.
If you can’t find a suitable replacement bolt, it’ll be new chain ring time.
Posted : 08/05/2022 7:56 am
Cheers, has a feeling that would be the answer. If they aren't meant to be removed why not use a rivet! ?
Posted : 08/05/2022 8:16 am
Get a Unite direct mount chainring and be done with bolts.
Posted : 08/05/2022 9:11 am
 mert
Just smack the security pin with a punch, take the now non-security T15 bolt out and buy some new ones from your local DIY place...
Posted : 08/05/2022 10:44 am
I'm pretty sure they were supposed to be permanent so should never have come loose in the first place and also why they are deliberately a weird size. You are just meant to replace the whole chainring.
Posted : 08/05/2022 11:15 am
They are there because it’s a steal outer ring on an aluminium carrier.
Posted : 08/05/2022 11:41 am
Have got them out now. 3mm of m3 bolt with what looks like blue thread lock on. Bolt has a stepped shoulder and low profile head. Very proprietary and very stupid design. Well done shimano...
Posted : 08/05/2022 12:37 pm
