I'm struggling to find a narrow/wide chainring on a UK site that's going to enable me to keep using my middleburns that have a 5 arm compact spider.
There must be one of there, any ideas?
Do absolute black do one? Or wolftooth
I think you will struggle, 5-bolt was pretty much dropped quite a few years ago so 99% of the new chain rings will be 4-bolt. Could be new crankset time.
Good spot, but where do I get one over here?
It might be worth getting a 4-arm, 104BCD spider, it would give you more choice for chainrings and let you keep your middleburns.
Actually, don't middleburn do a direct mount N/W?
[url= http://www.middleburn.co.uk/products/spiders/mountain-bike ]lots of choice, no N/W though...[/url]
But you could still go four arm.
http://www.wolftoothcomponents.com/products/direct-mount-for-middleburn-cranks
Can be installed on non- X-Type Middleburn cranks but a longer spindle bottom bracket will need to be used to acheive an optimal chainline
been through this too, 94BCD NW's are hard to find, and the only ones I know of are expensive once you add shipping.
The easier option is just get a new spider, they are easy to swap on Middleburns and will give you access to a lot more choice in rings.
And yes, MB do list a RS7/8 (not X-type) direct mount NW ring, it's expensive though.
[url= http://www.middleburn.co.uk/products/spiders/mountain-bike/spider-rs7-uno-thick-thin-single-ring ]http://www.middleburn.co.uk/products/spiders/mountain-bike/spider-rs7-uno-thick-thin-single-ring[/url]
SJS are listing them too but currently out of stock
[url= http://www.sjscycles.co.uk/middleburn-rs7-uno-square-taper-thick-thin-spider-hardcoat-32t-prod37145/ ]http://www.sjscycles.co.uk/middleburn-rs7-uno-square-taper-thick-thin-spider-hardcoat-32t-prod37145/[/url]
Also here:
[url= http://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.sf/en_GB/?ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/SP-SQ-UNO-TT ]http://activesport.co/epages/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e.sf/en_GB/?ObjectPath=/Shops/80c85f8f-7a95-4b1c-9c30-e64b314f3f2e/Products/SP-SQ-UNO-TT[/url]
I gave up looking! I got a Shimano road 34t ring, alloy with no ramps/pins and was only £5. Fitted a Superstar chain guide and running an 11-32 9 speed cassette with an old XT non-clutch mech and I've never dropped the chain yet 🙂
