Help me decide plea...
[Closed] Help me decide please...
Firstly lets set out the ground rules.
1. I only have space for 2 bikes
2. I have little cash.
3. The wife says I need at least 2 bikes or I'm grumpy if one breaks and I can't ride.
OK, now that's out the way I shall continue...
I have two bikes at the mo, my 'good' bike, a trek 9.8 hardtail, reba's and XTR/XT mix. Nice bike, like riding it, and a 'hack' On One Scandal 29er. rigid, geared with a mix of deore, raceface and erm, 105...(plus whatever I could find in the shed)
Bought the scandal about 4-5 months ago, intended as an early morning ride-then-stick-in-the-shed-to-clean-later bike. trouble is, since getting it, I've used the trek once.
I'm toying with the idea of upgrading the scandal a little, with some bits from the trek, then splitting and selling off the trek, then buying a cheap (something like the B'Twin) road bike for occasional roady rides and getting me back and forth the 1 mile trip to work (currently using the very mucky scandal!)
So, Am I nuts? Should I just leave be, or is it worth trying to grab a change.
Advantages I can see include:
1. I like riding the 29er (I'll put some sus forks on it)
2. a roady will mean I'm a little cleaner when I turn up to work (with appropriate mudguards natch..)
3. I'll not have one bike sat in the shed doing nothing.
4. I may smile more (unlikely though)
Disadvantages:
1. I may not be able to run a negative or equal balance on the swap over..(that's quite important for wife's approval)
2. I'll only have a road bike if the scandal has a mechanical..
help
Posted : 17/01/2014 10:15 am
not sure you need a road bike for a 1 mile ride you could do that on anything
Get what you will use most often and need most in this scenario a road bike is unlikely to be the answer
Get a cross bike and a FS MTB would be my solution if i only had two bike tbh.
Posted : 17/01/2014 10:28 am
The wife says I need [b][i][u]at least[/b][/i][/u] 2 bikes or I'm grumpy if one breaks and I can't ride
Somewhere between the two.....There's your answer
Upgrade the Scandal with the pick of the bits from the Trek, if a 29er is your favourite now. Keep the Trek as a mudplugger, maybe even convert it to a SS. And get a cheap road or CX bike anyway. You can find space somewhere.
Posted : 17/01/2014 10:33 am
hmmm, nope that's not going to work..
CX bike would fit nicely alongside the 29er.
When I say the roady will be used to get to work, it would also be used if I fancy a road ride. I don't do road rides much now as I don't like riding knobbly tyred bikes on the roads 🙂
so, I guess next is recommend me a cheap as chips CX bike or roady, budget will be no more than £350 (hence the B'Twin mentioned..)
Posted : 17/01/2014 10:49 am
CX season will be over in a couple of months, pick up a second hand bargain. keep your powder dry until then.
Posted : 17/01/2014 10:53 am
