I need to replace the bearings in my rear DT OEM hub, but unfortunately I have no idea what it is, so i'm not sure what parts are compatible with it. They came on a Canyon Nerve AM 7.0 (2011).
I've tried asking Canyon, they referred me to DT Swiss, who just don't reply to their contact form...
The wheels and hubs were just listed as "DT Swiss AM 1800" on the original product page, all the stickers on the hub are long gone.
Any help much appreciated, else I'll just take it to my LBS.
Thanks!
By looking at the hub drawings in here you should be able to work out what hub you have
Most oe hubs seem to be 340 or onyx but do check
http://www.dtswiss.com/Support/Service-Videos-Documents
Thanks I'll check that out.
I was hoping to not have to disassemble it before getting the replacement parts, but I guess I'll have to ๐
Robodan, did you manage to confirm what's used? I have an 2012 model with the same problem
Quick advanced warning, if your freehub has a bearing marked 6001, it isn't actually a 6001, but (pretty sure from memory) a 16100.
