Help! I can't ...
[Closed] Help! I can't get my tyre on....
Any tips on fitting a very tight tyre on a new rim?
Posted : 11/05/2010 10:16 pm
washing up liquid to tyre bead and rim & tough plastic tyre levers
Posted : 11/05/2010 10:28 pm
start opposite the valve first
[u]constantly[/u] check the bead is in the well of the rim
washing up liquid
Posted : 11/05/2010 10:38 pm
Washing up liquid solution. Always worked on motorbike tyres back in the day. And they are much harder to get on than cycle tyres. In my experience though I appreciate there are some very stubborn combinations about. I recently got one of the Crank Bros tyre levers from one of those Sunday morning cycle sales for £3.00. They can be used for fitting as well as removing and I have found they help a real treat. I'd advise even buying one at full price and triply so if you can get one for £3!
Posted : 11/05/2010 10:51 pm
Been trying since half 7 to get this sodding tyre on, and it's still not happening! 👿
Posted : 11/05/2010 11:18 pm
 nuke
Is this for use with inner tubes? What happens if you get a puncture on the trail?
Posted : 11/05/2010 11:24 pm
I had a nightmare with some tyres recently - did some asking around and picked up one of these: [url= http://www.wiggle.co.uk/p/cycle/7/Crank_Brothers_Speed_Lever/5360019204/ ]Crank Bros speed lever[/url].
Made the job a whole lot easier. Plus it even speeds up removal too.
Posted : 11/05/2010 11:28 pm
 sv
There is a handy video on the Stans website showing on to get UST tyres onto their rims. The method would work for normal tyres too and the speed lever is very good too!
Posted : 12/05/2010 7:49 am
washing up liquid and water. Start opposite the valve as said above. Every time the tire gets to the point it's tight you need to go back round the bit you've already got onto the rim and make sure that both beads are pushed into the central well. Once you've checked that you should get another few mm's onto the rim, then go round again. Keep on doing it until you're there. Make sure there's no air in your tube too, that's stopped me in the past.
That's what I've learned from having to get dual ply HR's onto my FR2350 rims. It seems impossible at first. I still have to use tyre levers for the last little bit though. If I get a puncture on the trail you're going to hear a lot of swearing!
Posted : 12/05/2010 7:58 am
Start shouting at it, aways works for me
Posted : 12/05/2010 8:35 am
Thanks Spacemonkey. Just got a speed lever, and had the tyre on in a matter of seconds. Then off because I'd forgotten to put the inner tube in, then back on again!
:mrgreen:
Posted : 12/05/2010 3:09 pm
I got one of the cyclo levers for christmas. Great piece of kit, what would take me ages now takes seconds and no more broken nails
Tracey
Posted : 12/05/2010 3:15 pm
