Fox 36 2007 with springs, how do you get the lower legs off, small nut frees LHS leg, large nut on RHS leaves larger thread with small nut on end that rotates thread if turned but still seems attached to leg. Did not want to use too much force to pull legs off to clean out. Advice please.
Posted : 20/03/2009 8:55 am
half undo the nut and then hit the socket with a hammer to free the stud as it's an interferance fit with the lower leg if it's just an oil or seal change that's cool but don't try and dismanle the damper cart. as without the proper tools you'll damage it. Refer to the fox/mojo site for instructions.
Posted : 20/03/2009 3:36 pm
