Help: fitting an al...
[Closed] Help: fitting an alfine on slot inbred
Bit confused with fitting an alfine on my recently purchased new slotted 26er inbred. The washers go on the inside of the dropouts with the anti turns on the outside both facing back out of the frame? Do you need the anti turns? Also the cable guide on the alfine doesnt align well at all, supposed to be horizontalish I guess? Might be that I havent put the fitting kit on right on the alfine with all the alignment stuff?
Posted : 01/07/2011 8:47 pm
 mboy
Silver and White anti turn washers required, fitted OUTSIDE the frame, and fitting is a doddle. How on earth have you made a muddle of it?
Posted : 01/07/2011 9:42 pm
Both washers and anti turns outside of the frame?
Posted : 01/07/2011 9:57 pm
what washers? on both my 11 and 8 there are no washers that i can think of - only the anti turns... (which are fitter to the outside, and yes you do need them - if you wnat to change gear)
Posted : 06/07/2011 8:37 am
some slot drop inbreds have taper washers on the inside of the dropout to help stop the wheel sliding forwards.
Posted : 06/07/2011 12:47 pm
hey monkeyboyjc
How's your alfine 11 running?
I've an 8, but want to get an 11. Not sure about some issues i have heard about poor/tricky shifting?
Posted : 06/07/2011 12:56 pm
