Help - DIY Mechanic...
[Closed] Help - DIY Mechanic C0ckup with X9 Shifter
In my infinite wisdom I decided to dismantle my right/rear X9 shifter. There was a purpose to this as I was replacing the gear cable. Unfortunately during said tricky operation I decided to fettle, stripping the shifter further and then was dragged away due to work (this is the problem working from home).
Anyhoo, I'm struggling to put the thing back together and could do with some help. The front cover is off as are the two springs. The thumb shifter is off also revealing spring and two random pieces of metal.
I've tried the LBS but the usual two mechanic heroes who save me from myself are not there. So, in order to correct this I need some sort of technical document (or link) that details the X9 internal components. The one on the SRAM website and subsequentlly the one I received with the shifters isn't much use. Anyone?
Posted : 04/06/2009 11:20 am
 Jay
http://www.sicklines.com/tech/howto/sram-x9-shifter-rebuild/
Hope that helps
Posted : 04/06/2009 11:28 am
I had an x-9 shifter go completely in pieces so bought a new one in the flood sale. this could be really handy. thanks.
Posted : 04/06/2009 12:08 pm
Errr, thanks dirtbiker, I'll consider that as a final option.
Thanks Jay. The shifter being rebuilt is different to the one I have at present although the lever mechanism is similar.
What I have managed to do is piece it all back together apart from the spring shown in the second diagram of step 10.
I'll keep plugging away.
Posted : 04/06/2009 1:18 pm
Sorted. Found it. Thanks.
http://www.ridemonkey.com/forums/showthread.php?t=206749
Posted : 04/06/2009 1:24 pm
I assume Dirtbiker meant the link was helpful for his shifter, not that you should buy a new one!
Posted : 04/06/2009 1:31 pm
