Help choosing a fro...
[Closed] Help choosing a front mech please
I was all set to buy all the bits I need for the Inbred frame I was planning on buying this evening, until it came to the front mech....
I was planning on getting an SLX one. The Shimano website says that the clamp size is suitable for 28.6/31.8/34.9mm seat tube post......but the Inbred seat tube is 29.8mm.
Does this mean that the front mech comes with spacers & you fit the closest clamp size to your tube with spacers if necessary? I really don't want to order the wrong thing & have to send it back. The only mechs I have bought for the old bike are the ones that have an e-fit bracket for mounting off the BB.
Also, there seems to be a top-swing or down swing......what's the difference? What's the advantages? What's the best one to go for on an Inbred frame....?
As far as I can see it, one has the clamp above the level of the chain guide & one has the clamp sat lower.....
Any help would be appreciated as I wanna buy all the bits tomorrow at the latest or I'll never get round to it!!
Posted : 18/04/2010 9:17 pm
Down swing lasts longer.
Your seat tube will be 28.6 - butted externally at the top.
Posted : 18/04/2010 9:19 pm
down swing sounds like the way forward....
The On One site definitely says 29.8mm front mech clamp size for an Inbred, but I can see your point about the seat tube being butted up to 29.8 from 28.6mm at the top.....hmmmm.
Posted : 18/04/2010 9:29 pm
Bottom swing FTW. They last SO much longer and dont catch mud like top swing ones do.
Posted : 18/04/2010 9:46 pm
Well, I rang On One and it's a mistake on their website; you were right cynic-al - it's 28.6mm and is on their website to-do list of things to sort out.
Ended up getting an SLX mech in the end - can't remember what way it swings though.
Posted : 19/04/2010 2:40 pm
Hijiack
Maybe a stupid question, but with the 34.9 to 28.6 clamp work for 31.8 to 28.6?
I'm not sure if i'll require a 'middle' size
http://www.chainreactioncycles.com/Models.aspx?ModelID=17423
Cheers Stumpy for contacting on-one...I couldn't find anything anywhere about 29.8 front mechs!
Thanks
Andy
Posted : 20/04/2010 10:43 pm
Also depends on the cable routing welded on your frame.
I need conventional but went with a top swing which works fine.
Posted : 20/04/2010 10:47 pm
Andy. Is your mech a multiple fit? That's what those are for.
If not you can bodge it with a stem spacer and a hacksaw.
Posted : 20/04/2010 10:51 pm
Not sure exact spec. Know it's 'XT conventional dual-pull'
We'll see what happens.
Just getting over excited about my first build. Cannae wait!
๐Ÿ™‚
I'll be back once I've calmed down and have proper details.
Cheers everyone
Posted : 21/04/2010 12:14 am
