Helmets for Ma and ...
[Closed] Helmets for Ma and Pa
Hi all, just need a quick recommendation for cheapish Helmets for my folks. Its been a long time since I bought anything that wasnt a Full facer.
They wont get much use and will likely spend most their time on along the canals etc.
I was looking at[url= http://www.chainreactioncycles.com/au/en/cratoni-miuro-womens-helmet-2013/rp-prod88203 ]cratoni miuro womens helmet[/url] and [url= http://www.chainreactioncycles.com/au/en/cratoni-c-flash-helmet-2013/rp-prod88197 ]cratoni c flash helmet[/url]
Crationi are not a brand I know. Doesn't have to be anything special just cheapish, comfortable and easy to adjust. Any recommendations?
Cheers in advance.
Posted : 07/03/2014 6:34 am
Only rule with lids is one that fits. Take them into a shop.
Posted : 07/03/2014 7:15 am
 cp
As above, one that fits... for comfort as much as anything.
You got a decathlon nearby?
Posted : 07/03/2014 7:23 am
Have a couple of the On-One helmets - good value, great fit and really light.
£19.99 delivered - can't go wrong!
Posted : 07/03/2014 7:59 am
Unless it doesn't fit your head in which case it's no use.
Posted : 07/03/2014 8:24 am
Unfortunately I'm in Australia and they are in the UK so a bit of a distance for me to go for a helmet fitting.
Posted : 07/03/2014 8:28 am
Then I suggest you find somewhere near them who can get them in a well fitted lid. Plenty of lbs will do that.
Posted : 07/03/2014 8:39 am
Uvex are very well prices, light and reasonably well rated by the press.
As above fit is everything though, I used to buy giro helmets, the new giro wouldn't fit so I move onto Bell which does...
Posted : 07/03/2014 10:17 am
get them to measure their heads.
Specialized Align is a very comfortable helmet and has a size range of 54 to 62
women specific version is called the sierra and has a size range from 50 to 58 and is a better shape for a womans head
PS Cratoni helmets are very good. about 90% of helmets are made in china in the same factory companies set a budget and tell them what they want it to look like.
Posted : 07/03/2014 10:22 am
