Hello STW, does any...
[Closed] Hello STW, does anyone own a 2005/2006 Scott Ransom?
I need some info about the frames and could really do with a hand!
Any help appreciated, Kael.
Posted : 23/03/2011 11:58 am
Mate of mine had a ally ransom 30 which broke pretty quick, scott replaced it with a carbon one for a small upcharge which is still going strong,
His has 36's and a pretty burly build and gets ridden regular enough, the shock is a 190x50 so the leverage ratio is high and the shock takes some scary pressure if your a biffer, and you need a Scott high pressure shock pump that go's over 400psi too set it up
Edit, the pump has the no loss gubbins on the end like a magura one too
Posted : 23/03/2011 12:42 pm
