HEL Brake Hose
[Closed] HEL Brake Hose
[#481678]
Evening...
Anyone used the HEL Brake Hose kits?
What's they like?
P
Posted : 17/04/2009 10:22 pm
My partners had them fitted to her new Yeti. Bike shop said it was really easy to fit as it came with a whole assortment of fittings to suit different brakes.
LBS reckoned it was alot better than the usual Goodridge kits he has to fit for customers.
I will be getting a set for my Orange sometime soon. Can't recommend HEL kits enough. Get it!
Looks trick in Black!
Posted : 17/04/2009 10:54 pm
Cheers Nick...
I think a purchase my be in order!
P
Posted : 18/04/2009 1:02 pm
top brakelines - can't recommend them enough
easy to fit and unlike goodridge they don't try to fleece you for fittings every time
Posted : 18/04/2009 1:29 pm
You do however, need a dirty great vice to adequately swage the ends. You will stand no hope of acheiving the required pressure for swaging with a set of pliers, molgrips or similar.
Posted : 18/04/2009 2:05 pm
Swaging?
Posted : 18/04/2009 5:36 pm
popular in the motorbike world, can't say i have experience but they are recommended
Posted : 18/04/2009 5:55 pm
Popular just about everywhere high pressure hose unions are required.
Posted : 21/04/2009 10:27 pm
swaging is crimping the fittings onto the end of the hose.
Posted : 21/04/2009 10:50 pm
I brought a set when they were on offer at CRC. I can't say they made a huge amount of difference to the feel of my brakes (Hope minis). You'll certainly need a vice to get the ends crimped on.
Posted : 22/04/2009 7:39 am
There aren't any seals between the hose fitting and the caliper if you're using old-style shimano brakes, which meant mine leaked badly from this point.
This was almost certainly due to my mechanical ineptitude and general stupidity (and if anyone knows what I did wrong, I'd love to know), but even I've never managed to get it that wrong when fitting goodridge or OEM hoses...
I'm not buying them again.
Posted : 22/04/2009 8:52 am
That what the brass washers are for. You crank them hard enough and because they're relatively soft, they make the seal.
Same as hope brakes.
Posted : 22/04/2009 9:30 am
The only criticism I have of mine is that I can't shorten the front one now I've transferred them to another bike.
Posted : 22/04/2009 10:31 am
I swaged one end and fitted some spare goodridge fittings to the other to deal with that.
Posted : 22/04/2009 10:54 am
Wonder if I've got some spare Goodridge fittings? I may have (having used Goodridge on t'other bike)
(also wonders quite why I need to shorten the hose in the first place - the new bike has the same bars, same stem, same headset, longer headtube & longer fork (Marz 55 vs Pike) but there's loads of hose flapping around)
Posted : 22/04/2009 11:00 am
I have used them, easy to install and very very good!
Posted : 22/04/2009 11:59 am
[i]That what the brass washers are for. You crank them hard enough and because they're relatively soft, they make the seal.[/i]
Aha. Wish I'd known that or there were some instructions with mine to tell me!
Posted : 22/04/2009 8:12 pm
