Heavy duty flat ped...
[Closed] Heavy duty flat pedals - which one?
I need something robust. DMR V12s - went all clicky after nine months and didn't fancy the £25 service pack - that's two pairs in under two years
Burgtec M4 Composite lasted two rides.
I'm 100kg and climb hard.
What are your longlasting recommends please lovelyl people?
Many thanks
Posted : 04/05/2020 10:29 pm
got the XT ones. They're brilliant. And Huge
very very grippy
Posted : 04/05/2020 10:53 pm
The most robust pedals I’ve had are the Carbon Cycles Exotics I think. I actually prefer my Superstar Nanos but if you’re heavy I’d prefer more bearings for longevity so I’d take the Exotics. They’ve also been bashed off a fair mount of rocks / logs etc and still look in on shape.
Rebuilt kits (of which I haven’t needed one yet) are only £10 too I think.
Posted : 04/05/2020 11:00 pm
I'm approx 95 kg and ride flats exclusively, current pedals of choice are the Chromag Scarabs which i've been using for about 2 years on the singlespeed (and another newer pair on a full sus) with no issues. They are expensive, yes but they are good, best flats i've had. Quality materials and seals, bearings and bushings are original and still going strong. I like that you can tune the pin length, number of pins ands pin placement per pedal. Before the Chromags I had DMR Vaults which were good until one of the pedal axles snapped mashing the singlespeed uphill(!).
Posted : 04/05/2020 11:24 pm
In fairness I had a set of v12’s for 12 years without replacing a bearing. Last set 5 years just stripping and regressing from time to time. When I think robust I think v12.
Posted : 04/05/2020 11:43 pm
Thank you will look into them
Posted : 04/05/2020 11:50 pm
Sounds like the v12s you have got are the old style that lasted forever
Posted : 05/05/2020 10:10 am
I've had Nukeproof Horizons for a couple of years, 1 pair and have been great. Haven't had to do any maintenance with them so far.
Posted : 05/05/2020 10:35 am
Burgtec mk4 pedals at 110kg have seen me right for almost 5 years with 1 service kit. Was kind of hoping they would die as the new mk5 look a nicer wider platform for my bigger feet but the mk4s just keep going. No longer look black though!
Posted : 05/05/2020 11:12 am
 tish
My burgtec composites didn’t last 2 months, I sent them back and they said they have repaired them. They were posted back to me Monday so I’m expecting them soon, I’m presuming they have just changed the internals. Shame really as I like the feel of them but I don’t think I’ll be getting them again. One up got recommended on a post on here, I think I’m trying them next.
Posted : 05/05/2020 11:29 am
My Burgtec comps also haven't lasted well. The internals are shyte. Not as shyte as DMR Vaults, which are spectacularly shyte. The have both been resigned to the spares bin. OneUp also went the same way, but the also felt rubbish too, due to a lack of concavity. They bypassed the spares bin & just went in the actual bin.
The best lasting pedals I have had are the Nukeproof Horizons. I have smashed a set into all sorts over the years & they are still going strong on the original bearings & bushes, with no play & no rattling. Just got a set of the newer style ones for my other bike. So they get the thumbs up from me 🙂
Posted : 05/05/2020 11:35 am
Burgtec penthouse mk4 on both my Bronson and my commuter, bomb proof.
Posted : 05/05/2020 11:55 am
The Unites are my new go to. Super nice very robust and made in the UK. Long term is a bit tricky but I know a bunch of people on them all still running smooth AFAIK (including my own). Longer than I would expect to get from some on the list above!
Posted : 05/05/2020 1:16 pm
If you wanna try some secondhand Slim Jims (in white though), drop me a message.
Posted : 05/05/2020 1:48 pm
Nukeproof Horizons, I used them before going clips, 4 of my riding buddies still use them. Service kit and spares are easy to come by via CRC too.
Posted : 05/05/2020 1:53 pm
@trumpton I did have the old v12's and they just lasted. I gave them away after 12 years and duty on 3 bikes and were still spinning as smooth as new. The new slimmer ones don't seem to seal as well, but if you are prepared to service them regularly they should last forever. I've got 2 pairs here one of which has a bearing which is starting to go. But I'm 14 stone, big bike, gritstone area, jetwash through boggy winters etc.. can't complain.
Posted : 05/05/2020 3:23 pm
 JAG
I'll second the Carbon Cycles Exotic pedals.
Very nice looking and tough-as!
I've only had them 9 months but no problems so far ;o)
Posted : 05/05/2020 4:24 pm
Looks like if you want a pedal to last go for a thicker chunkier profile pedal like everyone used to have
Posted : 05/05/2020 5:58 pm
