Headset what size?
[Closed] Headset what size?
Non overdrive Giant Anthem 29 2102/13? I want an angle headset. https://www.superstarcomponents.com/en/slackerizer-angle-headset.htm
The steerer looks like a semi integrated with a top bearing 42 outer 31 inner and bottom 52/40 ish. Frame steerer length is 106mm.
Is that enough info to work out what I need?
Posted : 25/11/2020 2:30 pm
I believe you want the ec44 zs56 tapered in appropriate length for an anthem but not sure.
T7-2 on that list.
Make sure you've 2 spacers under your stem at present.
Posted : 25/11/2020 2:32 pm
20 mm of spacers under stem.
Posted : 25/11/2020 2:36 pm
