headset installatio...
[Closed] headset installation grease or no grease
as above i just cant remember ta
Posted : 23/03/2009 4:30 pm
grease, in headtube where cups go and fork where crown race sits
Posted : 23/03/2009 4:34 pm
cheers i couldnt remember but thought i should ๐Ÿ™‚
Posted : 23/03/2009 4:36 pm
With the exception of DU bushes [which are self-lubricating] - any metal to metal mating should be either lubed or thread-locked
Posted : 23/03/2009 4:37 pm
Are you supposed to grease the crown race itself, and the top of the bearing cartridges? I serviced mine at the weekend a couldnt remember as well so greased both.
"Are you supposed to grease the crown race itself, and the top of the bearing cartridges? I serviced mine at the weekend a couldnt remember as well so greased both. "
I do just to stop it rusting when water inevitable runs out of thr frame tubes via the headset
Posted : 23/03/2009 6:02 pm
Posted : 23/03/2009 6:08 pm
I use a bit of copper slip when I'm installing headset cups. Think I got the Finishline stuff which comes with a brush...the amount I use it, the whole pot should last me years
Posted : 23/03/2009 6:11 pm
dunno, i use bearing lock, works like grease duing instalarion and bedding in (helps things in and stops things squeeking like buggery). Then sets to stop them falling out/moving.
Posted : 23/03/2009 6:19 pm
