Hi
Reckon I found where the creaking ia coming from...the headset..it has some weird internal thing from cane creek. On bottom it has no cups just an internal spliced thing which sits in loose and then a bearing...is this right?
I reckon the creaking is coming from the lower bearing rubbing against this spliced thing?
Any ideas...the bearing seems pretty smooth running so dont want to buy a new bearing if this isn't needed
Kwack
Clean it all out and smear fresh grease over bearing/cups and refit it.. Job done.. ๐
They 'dry out'.. as above should solve it. Dont over tighten topcap.
Out of interest, how tight should one do up the top cap on a Campy style integrated headset? I have one on my Specialized Camber and I've never been able to work out how much to tighten it?
I cleaned it out a couple of weeks ago when I fitted new forks
Just so I understand..the bearing sits underneath the spliced thingy..it doesn't have to be pushed up into it does it?
For the bottom there isn't any cups just the spliced bit pushed up which falls out when taking forks out the bearing rests up against it..then forks with crown race on?
Kwack
If it's all cleaned but no grease it's the bearing/crown race/cups creaking together(grease prevents this)
OK will a trip down again and load up with grease I only out a small amount last time.
Just to be sure the lower bearing sits below the spliced bit rather than inside it? As I couldn't seem to push inside the spliced bit
I searched on internet but couldn't seem to find any advice
Kwack
If this is what you mean ? Bearing sits on top
Yup, below. It's a very weird proprietary set up. See page 4 of:
Cheers I will strip down and take a look again....
Cheers all
Kwack
