Anyone help with what headset bearings I need for a Ritchey P-29er? Original items too corroded to see the sizes stamped on them.
The original one (straight headtube) would be [url= http://www.tritoncycles.co.uk/components-c9/headsets-c79/ritchey-comp-drop-in-headset-p10691 ]IS42/28,6-IS42/30[/url], while the newer (2016+, tapered) is [url= http://www.tritoncycles.co.uk/components-c9/headsets-c79/ritchey-comp-drop-in-tapered-headset-1-1-8-to-1-5-p10656 ]IS42/28,6-IS52/40[/url].
I have the newer one and found that a Hope headset wouldn't fit properly, there was a 2mm gap between the top cap and the frame; using a Ritchey-branded top assembly sorted this out (the bearing sits a bit deeper inside the frame).
thank you otsdr...mine is an original model. thanks a million
