Head torches for lo...
Head torches for long distance walk…?
 Bez
Yeah, I know it’s a walking topic in the bike forum… bite me 🙂
I’m planning a 70 mile walk which will include 10-11 hours of darkness (admittedly parts of that will be streetlit), so I need a suitable head torch.
The Petzl Swift RL and Nao RL both look tempting, but at £100 and £150 respectively I’m curious as to which is the more suitable choice, and how much they offer over what I currently have. I’ve not used the Reactive Light feature so I’ve no idea how useful it is.
At the moment I have a Zipka, which is light and zero-cost and does the job—at least for close range—but I’d need to carry a fair few batteries, and I’m not convinced its cheesewire headband would be terribly comfortable for an entire night. It also isn’t exactly great for seeing distance (it wouldn’t pick out a gate across a field) and while I could pair it with my Joystick Mk7 on its neoprene head band, that’s just adding to concerns about comfort. (I’ll give them a trial run, though.)
So does anyone have any recommendations? Either the two mentioned above or something else. I’d consider a chest light (mainly to reduce the problem of reflection from clouds of damp breath) but I suspect that’ll be too fiddly with a rucksack.
Muchos gracias 🙂
Posted : 05/12/2022 10:20 pm
Ey up, for years I used my trusty Petzl TacTikka, on the low setting it seemed to last forever. Of late I upgraded to the Actik CORE 450, it has a rechargeable pack but also runs off AAA. I bought a spare rechargeable and swap them out, charging the drained one in my bag, then have AAA's as a back-up. Gives me coverage from last to first light and then some.
Posted : 05/12/2022 10:28 pm
+1 on a Tikka and be careful with full power. One set in headtorch and another 6 batteries should easily see you good.
Posted : 05/12/2022 10:38 pm
I've been using a chest light for running. It works fine but you're right that it can be a faff with any sort of pack.
I have a LED Lenser H7. That's comfortable to wear, stable, very adjustable and runs off AAAs so could be made to last if you carried a few extra.
I have a petzl bindi - huge runtime on low which is Ok for walking with once your eyes become adapted and bright settings that shine a long way.  It also charges from a mini USB so a small powerbank will give you loads of runtime even on high.
Light adaptation tho should mean you really don't need a light at all for much of it unless its a moonless night or you have rubbish night vision.  Also the bindi has a red light so as not to lose your adaptation
Its my favourite of all my head torches and I have a few
Posted : 05/12/2022 10:39 pm
Mine was the OG with the flip up red filter, lasted forever! Tried to find one but alas, no joy. Sad times when it died on me, many happy memories. 😂
[url= https://i.ibb.co/7YQ8SVt/64b0ee19b89036842610f562eb73a190-red-filter-petzl.jp g" target="_blank">https://i.ibb.co/7YQ8SVt/64b0ee19b89036842610f562eb73a190-red-filter-petzl.jp g"/> [/img][/url]
[url= https://imgbb.com/ ]free image hosting[/url]
Posted : 05/12/2022 10:46 pm
Cheaper Alpkit torch and decent rechargeables (Eneloop) should be loads cheaper and you can use the batteries elsewhere.
https://alpkit.com/collections/head-torches
Posted : 05/12/2022 11:05 pm
Don't overthink it. I frequently wear them for long periods (Ayup or Petzl Tika) and did an overnight 60 miler once. Just used whatever head torch I had and just carried more spare batteries than I needed.
Posted : 05/12/2022 11:56 pm
Small Olight which has a double sided clip. Can use as a hand-held torch or can be clipped onto a cap.
If it has to be a head torch then the Perun Mini is quite a good option. But is the torch to see, or be seen?
Posted : 06/12/2022 3:36 am
I've got an Olight as well, older H1R. Does 20 hours on low apparently so something similar with a pair of batteries would see you through the run with some mixed use.
Posted : 06/12/2022 5:07 am
 mert
I'm using one of the cheaper rechargeable olights.
Not sure what the actual run time is but I've only charged it once since I bought it last summer. Officially I think it's something like 16 hours on low. Which has worked well for just about everything I've used it for.
Apparently it's an HS2.
Posted : 06/12/2022 7:06 am
Energizer Lithium batteries will give you twice the run time of a rechargeable so if weight is an issue. Black Diamond Icon will do it on a single set of batteries - I’ve got 24hr+ out of one set at -20C and below.
Posted : 06/12/2022 7:20 am
I've got a Led Lenser NE010R which has a long runtime and is very bright on the higher settings.
For your purposes though I reckon the suggestion of a Petzl Actic Core with a spare core is spot on.
Posted : 06/12/2022 7:24 am
Can you take the cheeswire headband of the zipka and fit a normal headband?
New Petzl headbands are about a tenner. Replaced one on a 15+ year old Tikka+ in the summer as it was too saggy to use.
Edit: the new Tikka has a boost mode that does let you see to the other side of a field but draims the battery faster. It's way brighter than my old tikka+. You can fit a rechargeable pack and then take normal batteries for backup.
Posted : 06/12/2022 8:03 am
 Bez
Thanks all, a few to look at there.
I think the Actik and Tikka are too similar to the Zipka to be worthwhile—I’ll either go for a bigger step up or none at all.
The Black Diamond looks great for run time, but at three times the weight of the Petzl Swift (yeah, I know more runtime means more weight)…
I think Swift is still the one that’s tempting me most, as it looks like a good step up from the Zipka without much weight penalty… anyone used one?
Posted : 06/12/2022 8:57 am
I've got a Swift RL and it's a fabulous running light, the reactive feature works well but I wouldn't be happy using it as my only light for that length of time. I think I’d want a head torch that could take replacement batteries even at the cost of carrying more weight. You can get a spare battery for the Swift but that’s more speedy still.
Posted : 06/12/2022 9:16 am
 Bez
True, but on paper it should be able to do the whole night (certainly on low, and probably on medium, which matches the Zipka’s high for brightness) and I have the Zipka as backup, so even without a spare battery it should be ok in theory.
Posted : 06/12/2022 9:29 am
