Head angle change
[Closed] Head angle change
[#10566771]
How much would the head angle change increasing travel by 10mm?
0.5 degree maybe??
Posted : 04/04/2019 5:54 pm
 DanW
About that or slightly less
Posted : 04/04/2019 6:18 pm
This site will help if you want to see what happens when you change things.
https://bikegeo.muha.cc/
Posted : 04/04/2019 6:31 pm
Thanks. Going by chart,it is 0.5 degrees
Posted : 04/04/2019 6:53 pm
It's not quite as much as 10mm in reality, because the sag will be proportionally greater. I changed some Yaris and Lyriks from 170 to 180 and the difference in head angle was hard to notice once on the bike.
JP
Posted : 04/04/2019 9:36 pm
On my fat bike I fitted a suspension fork which raised the front end and improved the steering.
I no longer run a suspension fork would an angleset be able to replicate the steering when using the shorter rigid fork?
Posted : 04/04/2019 9:50 pm
I worked it out at 17mm per degree once...
Slackening the head angle will have some of the effect, but there is also weight distribution and trail. So "dunno"!
Posted : 04/04/2019 11:05 pm
