Has the rebound dam...
[Closed] Has the rebound damping broken on my Fox 34's?
[#9580131]
I have a pair of 2016 Fox 34 Fit 4 forks with the red rebound at the bottom of the right leg.
When I wind the rebound to maximum I would expect the rebound to be very slow but it is not that different from the other end of the extreme. Do Fox 34s have a narrow rebound range or is it likely there is something up with mine?
On other forks with rebound full on the rebound is visibly slow but not so with these.
Posted : 30/09/2017 5:00 pm
There's usually a noticable difference between the two extremes, though full rebound won't be enough to almost stop the fork returning as it does with some other forks.
Posted : 30/09/2017 10:27 pm
Hmm, OK. Sounds like it is lacking but I'll test at the two extremes to see if I can notice or if there is just no difference. Good to know it should not got to that ultra slow point though.
Posted : 02/10/2017 10:50 am
Serviced them?
Posted : 02/10/2017 10:54 am
Check the allen bolt in the red adjuster knob is correctly tightened onto the recess on internal rod, just been through exactly the same with some older float fit RL's & that was the issue for me.
Posted : 02/10/2017 12:29 pm
mike - I had them serviced about a year ago then they were used a lot for two weeks (holiday in Oregon) but have seldom ridden them since (probably 10 times).
matt - thanks I will check that.
Posted : 02/10/2017 2:45 pm
Keppoch , just PM’d you
Posted : 02/10/2017 3:41 pm
