has anyone compared...
[Closed] has anyone compared a 27.5 2.8 trailblazer to a 2.8 nobby nic ?
curious as i cant go too much wider than my trailblazer on the rear but my sidewalls seem very poor ๐Ÿ™ dont want to buy and not fit, pretty sure a 3.0 nn wont fit. thanks
Posted : 01/11/2016 11:07 am
I haven't seem them side-by-side but I thought the TB came up narrow. Maybe get something in a "genuine" 2.5"?
Posted : 01/11/2016 11:09 am
They aren't [i]that[/i] narrow - the sidewalls stick out quite a way. ๐Ÿ˜‰
Posted : 01/11/2016 11:12 am
TB does indeed come up narrower
NN will is wider
Singlespeedstu recommended a WTB breakout in 2.5 when I had similar size constraints, and a bloody good tyre it is too. It's grip defies it's tread pattern, and sidewalls are bombproof too.
Posted : 01/11/2016 11:22 am
curious as i cant go too much wider than my trailblazer on the rear but my sidewalls seem very poor dont want to buy and not fit, pretty sure a 3.0 nn wont fit. thanks
FWIW I've just swapped out Trailblazers for 2.8 WTB Rangers. Not as aggro as the NN, but similar to you I'm not convinced I'll have clearance for a 3" tyre up front (a 3" Spesh Bround Control [i]just[/i] squeezes into the rear). Got a Tough Fast Rolling on the back and a Light Grippy on the front - good fun on local trails over the weekend. Clearances are around the same, except I now have side knobbles.
Posted : 01/11/2016 11:31 am
As above, the 2.8 Ranger TCS Tough is around the same size as a TB and so far hasn't exploded on contact with rocks... the Rocket Ron is wider thanks partly to the edge knobs and fragile with it. the Maxxis Rekon+ in 2.8 is also around the same size and might fit. Not as quick as a Trailblazer but a sight grippier and feels more robust too. But like for like with added grip, I'd go 2.8 WTB Ranger Tough.
Posted : 01/11/2016 12:41 pm
Thanks all
Posted : 01/11/2016 1:05 pm
I was running the trailblazers but binned them after they kept ripping when down to 14-15 psi. I've now got a 2.8 ninny nic in there and they are a genuine 2.8 wide from side to side nob. The transmitter looks ace now
Posted : 01/11/2016 8:56 pm
