Has any rounded (is...
[Closed] Has any rounded (ish) their BB, and succesfully removed it DIY?
[#6286771]
Help 🙁 lbs is charging £40 an hour
Posted : 22/06/2014 8:31 am
What sort of BB is it?
Posted : 22/06/2014 8:36 am
What type of bb?
By rounded-ish do you mean the teeth on the inside of a non-external BB?
Posted : 22/06/2014 8:43 am
Its a GXP threaded.. Hold on i will post pic
Molgrips.
Posted : 22/06/2014 8:46 am
Don't think he can help.
Posted : 22/06/2014 8:51 am
Maybe clamp it in a vice?
Posted : 22/06/2014 8:53 am
Not sure about "rounded" but I had one where the entire external cup sheared off leaving the threaded shell inside. Cut it out with a Dremmel - cut diagnol across the threads of the shell against the threads of the frame. Got it out OK and the new one sent in fine.
Posted : 22/06/2014 8:55 am
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140622_084612_zpst9g6wiz8.jp g" target="_blank">http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140622_084612_zpst9g6wiz8.jp g"/> [/IMG][/URL]
[URL= http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140622_084559_zpsmbwkniqj.jp g" target="_blank">http://i1073.photobucket.com/albums/w396/wolfenstein782000/20140622_084559_zpsmbwkniqj.jp g"/> [/IMG][/URL]
Posted : 22/06/2014 8:58 am
I have a shiny box of new style SLX cranks waiting to be fitted since friday 🙁
LBS havent seen it yet actually I just dropped them an email and they say in a worst case scenarion it's going to be a £40/hour job. 😐
Posted : 22/06/2014 9:01 am
You could drill a small hole in the top and bottom.
Put a screw in each hole and then clamp them with mole grips.
This would give you enough leverage to turn it I would imagine.
Not sure if this will work but may be worth a try.
Posted : 22/06/2014 9:03 am
Stillson wrench will get that out no bother.
Posted : 22/06/2014 9:06 am
yeah - I would take the cranks out and knock the bearings out of their cups then drill a pair of holes as camerph says, but big enough for a decent sizes screwdriver to fit through to use as a lever
Drilling top to bottom? But there is a bearings inside, can that be easily removed? ...
Posted : 22/06/2014 9:07 am
Looks like you've already used molgrips rather than the correct tool :(. There may be enough grip left if you have the correct tool? (or at least if the bike shop have it it won't take them an hour)
Buy/borrow a strap wrench - this would hopefully allow you to grip the BB even if the teeth are rounded off?
Posted : 22/06/2014 9:09 am
the bearings are press fit so will be bloody tight but not impossible to hammer out from the other sidewith a flat blade screwdriver (had to do it to a stuck xt bb before)
Should be easy enough to knock the bearings out wolf.
As olive says a screwdriver through the him should give enough leverage.
Hope you manage to get it out.
Posted : 22/06/2014 9:10 am
I used bb removal tool.. This:
http://www.wiggle.co.uk/lifeline-performance-external-bottom-bracket-wrench/
Have no problem removing an uberbike ht2 BB in other bike. Less succesful in GXP BB..
Actually just fitted BB last wednesday all kosher using parktool grease then hand to fully screw it in then tools to tighten it.. I ride in the thursday.. And wanting to removed it the friday and this happened 😐
Thanks, for letting me know that bearings can easily be whacked out., hopefully that would lessen the stress off the thread.. Then drill.. I cant sourced out a strap thingy without buying one.. Stillson wrench quite expensive 😛 and I dont think I will have enough leverage using molegrips .. Thanks all for the time. Somehow gave me an idea to DIY
Posted : 22/06/2014 9:12 am
Pipe wrench/stilsons will have that out quick smart.
Strap wrench is a waste of time as they cannot transfer a decent torque to that, its mostly for spinning things up as oppose to tightening and loosening
The bearings are under the area you have rounded not the thread , i would leave them in so they give the thin material some strength when your torquing on it, id also say that drilling through it isnt a great idea.
Posted : 22/06/2014 9:20 am
I'd start off by using a better bb tool.
One of these.
http://www.evanscycles.com/products/lezyne/external-bb-socket-tool-ec034141?country=GB&currency=GBP
Then get some threaded bar or a wheel qr and clamp it on nice and tight through the bb.
A pound to a pinch of shit it'll come out then. 🙂
Posted : 22/06/2014 9:22 am
Is this enough? Or have to get a bigger one?
http://www.screwfix.com/p/forge-steel-pipe-wrench-14/26843
Posted : 22/06/2014 9:30 am
 br
[i]Actually just fitted BB last wednesday all kosher using parktool grease then hand to fully screw it in then tools to tighten it.. I ride in the thursday.. And wanting to removed it the friday and this happened [/i]
All kosher, since when were molgrips 'kosher'?
Rather than now damage your frame through more cackhandedness, pay the LBS to get it off and buy a proper BB tool, a new BB and search for a video that shows you how to do it.
Posted : 22/06/2014 9:34 am
Think i used 18" wrench when my BB was wedged in. When the problem gets to this stage you want to guarantee results!
Posted : 22/06/2014 9:42 am
I once had a very stuck bb where I had to whack the bearing out, then very carefully saw through what was left of the BB inside the frame and gently prise it out. It worked but took a very long time :(. I'd be tempted to see if the bike shop had a better fitting BB tool as it does look from the photo as there is still quite a lot of 'teeth' there
The tool you linked to is open ended which means that if it isn't well made there is plenty of scope for it to widen enough to slip over the teeth rather than grip when things get tough
Posted : 22/06/2014 9:43 am
Big Stilson. Out in moments. Easy.
Bit of Plus Gas if it's corroded. Simple.
Posted : 22/06/2014 9:51 am
If its only been in there a week, you are turning it the wrong way or have cross threaded it.
Posted : 22/06/2014 9:57 am
BIG Stilsons as above ..... use them everyday getting stubborn lengths of pipe out
Posted : 22/06/2014 10:10 am
If both are stuck after only a week then it is likely you are doing something wrong. Are you unscrewing in the correct direction? Have you taken the cranks off 🙂 . It's difficult to believe that two would seize up in a week
Posted : 22/06/2014 10:13 am
Alternatively wait until you've really knacked it and THEN give it to the LBS
Make em earn their cash
£40 an hour isn't that much when they'll have it out in 20 mins
Posted : 22/06/2014 10:14 am
Where are you? Someone might have a big set of Stillons you can borrow. If you are in Sheffield I have some.
Otherwise, depends what tools you have and how medeival you want to get.
Hacksaw towards frame and cut 2 sides off to make flats. Put in a vice or use a big adjustable.
Through drill and screwdriver a good idea
Last resort, hacksaw blade through bb and cut as deep as you dare in 3 places then collapse the shell inwards with mole grips or screwdriver and hammer.
If you don't have stillsons, no real neat solution and all risk damaging the frame so take it easy!
Posted : 22/06/2014 10:16 am
I dont think i have cross threaded it as I screw it in just using my hand carefullytill I cant screw it in no more, its then i used the tools to tighten (which i thought is a decent tool till now).. I might get that lezyne bb tool as i need it anyway.
Thanks gravity salve .. Im in the midlands..
BB says to tighten. There is an arrow.. i am undoing it the other way..untighten.. Yes removed cranks.. Removing cranks is easy enough.. No issues there.
Posted : 22/06/2014 10:20 am
might have been cheaper if you had bought the cranks from the lbs and got free fitting?
They can't price match merlin ;
Posted : 22/06/2014 10:22 am
Are they close to merlin when you add in 40 quid labour to get old bb out 😉
Posted : 22/06/2014 10:23 am
As above.Stilsons...Two second job.It will come out easier than the proper tool. 😉
Posted : 22/06/2014 10:29 am
Stilsons rock - I just removed a stuck seatpost with one 10mins ago. Everyone should have one
Edit: quick Jamie, remove that before McMoonter sees it
Leffeboy - the 1989 Rockhopper stuck seatpost?
Posted : 22/06/2014 10:34 am
OP.
You say you're in the Midlands.
Ping us an email and if you're close to me I'll get it out for you with the correct tool for the job.
Posted : 22/06/2014 6:16 pm
not that one actually but given my success with the other I'm tempted. I love that bike too much too risk going down a line that might trash it though.
Posted : 22/06/2014 9:42 pm
