Hardtails - Carbon,...
[Closed] Hardtails - Carbon, alu, steel....
in the market for a new hartail mainly for racing on but not sure how the different frame materials will "feel".
anyone shed any light or sum it up for me.
had a hardtail in the past an sufferred a bit of low back pain after a few hours in the seat , probably due to the geometry of the frame more than the material i think, but how do the different materials feel out on the trail or is it all in the geometry and the Fit of the bike?
help appreciated...
Posted : 03/03/2011 2:58 pm
Steel is springy and lively. It has a character and a soul that runs deep. Its almost like your riding a full sus.
Alu is incredibly stiff and will give you a bad back.
Carbon is stiff and comfortable but will definitely shatter or turn to dust.
Ti has magical properties, the best bits of them all. There are no words to describe how good it is but its definitely worth the thousands of pounds it costs.
Posted : 03/03/2011 3:01 pm
 mboy
It's much more than just what they're made of that determines how they ride, geometry, design and material grades can all make a difference too (as can most likely, many other things!)...
But as a general rule of thumb, the following applies...
Steel - Heaviest of the materials, easiest to work with, has a "lively" character (as long as not too much of it is used) and should last a long time.
Alu - Quite a bit lighter than steel, can be shaped and formed into pretty much any shape you like these days to add strength and reduce weight. Not very lively unlike steel, can feel a bit dead or harsh to ride in comparison with steel.
Carbon - Lighter again (in general), you can make absolutely any shape you want out of it, but it's quite a bit more expensive than aluminium or steel. To ride, carbon is not as lively as steel, it can feel like it's absorbing the edge off some of the smaller bumps (a good thing or a bad thing, depending on your viewpoint, but why it's used extensively on road bikes these days).
And then there's Titanium - Most expensive of all the materials, generally frames are built around the same weight, or slightly lighter than alloy frames. Titanium is not so easy to work with, hence more conventional tubed frames are more common. Ride wise, it is best described as being more lively than steel, titanium has so much inherent flex in it that if not enough material is used in a frame, it can visibly flex quite a lot (though it probably still won't break). Some find it too flexy, some love the way it rides.
Personally, I prefer steel. I've ridden a number of each type of frame, and steel still wins out for me despite being the heaviest. But I'm not an XC racer though, so weight isn't so important to me.
Geometry and fit of a bike is probably more important than the frame material though, something to get right at purchase time. And the ability to run a big volume, fast rolling, preferably tubeless tyre in the back of a frame, can dampen even the harshest of alloy frames down noticably.
Posted : 03/03/2011 3:10 pm
They're all just bikes.
None of them will be bad, and there won't be a lot of difference between 2 of a similar type. ๐Ÿ™‚
Posted : 03/03/2011 3:12 pm
 P20
It varies between frames. Take steel for example. My P20 is light, comfy and a joy to ride. My 456 is harsh and heavy, but then again it's cheap. The 456 proves that tubeless tyres add comfort
Posted : 03/03/2011 4:34 pm
 IanW
I have just built an on one scandal with a carbon seatpost and fork which is comfier than any ht bike Ive ever ridden inc quite a few steel frames.
Steel definetly more robust but anything else Im not so sure now.
Posted : 03/03/2011 6:02 pm
