Hello everyone,
I want a rack for my mountain bike for the wall of my flat, so that when it is not being used it hangs out of the way. Because of the space, I am looking for one that hangs the bike horizontally, from under the top tube perhaps.
I've seen the cycloc one, http://www.cycloc.com/ but 60 quid for a plastic bucket with cutouts is taking the piss a bit.
Also so this, http://www.chainreactioncycles.com/Models.aspx?ModelID=5427
But it still seems a bit much for what it is.
Anyone seen any neat soloution for this, or some great big hooks or something?
Thankyou.
http://www.screwfix.com/prods/96114/Ironmongery/Hooks/Storage-Hooks/Retractable-Bracket-Black-320mm
£9 from screwfix? Not sure of the width - might need a bit of balancing or just get two.
Alterantively, these are £6.50 for two, will take 60Kg and you can slide some hose pipe or other soft rubber tube onto them as a bump.
http://www.screwfix.com/prods/77659/Ironmongery/Hooks/Storage-Hooks/Storage-Hooks-Black-250mm-Pack-of-2
Yes, big hooks availiable at B&Q, lidl currently has bike hoists in at the moment (at least last week they did) could put them against the wall too.. Will need to undo the stem steerer clamp bolts and twist the bars inline with the wheel to get it snug against a wall..
Lidl had one of those winch things in recently. I might be getting rid of an aldi bike rack similar to the crc link soon if you're interested.
Or remove the front wheel?
3 'hooks, fa the bars and saddle nose.
Some nice pully sytems out there, but i'd put it in the way so you'd need to keep movong it, that way you'll use it more.
Halfords have them check for £9.99
Didn't you do woodwork at school?
Go and try it - you might surprise yourself
Ha ha, yep thats an easier method Alasdair!
My brother used to have a dado rail in his kitchen that was ideal for storing his tandem. Sit your bike wheels on the top edge of the dado rail and secure the top tube by means of a hook in the wall and a loop of para cord or the likes from the hook round the top tube and back on to the hook. Obviously the bike is not parallel to the wall just slightly leaning out at the top.
that's a nice solution sturmey
[url= http://www.bikecare.co.uk/acc/cyclestands.html ]Got the Velomann one from this link[/url] - it's great, but only fits 2 MTBS.
You'll be needing a mountain ledge then...hangs from the pedal and cantilevers to the wall.
[url= http://www.fisheroutdoor.co.uk/public/index.php/product/storage/SH03.html ]mountain ledge clicky[/url]
I have two unused in my garage - let me know if you're interested...
Thanks everyone,
I_did_dab, can't quite see who that works, does it not put a lot of levering forces through the fixings and the crank?
Two hooks for a quid or so from Tescos, take the front wheel off and spin the bars, hang the front wheel from the pedal that rests against the wall. The hooks grab the saddle and the bars. Minimalist but it works and absolutely maximises space.
problem with the mountain ledge is you need something for one of the wheels to sit on to stop it tipping forwards or bakwards 🙁
Ikea. They do a galvanised vertical telescopic pole, and bike hangers which fit on the pole. Works out about £12 (I think). I've two (for storing four bikes) and have had no problems. Its caller'broder'and is in amongst the storage section in the catalogue.
I have hung them upside down from the ceiling before - need high ceilings (and tall-ness) I suppose
It does work if you have a flat wall long enough to support both wheels as well. Use long screws! An architect or engineer will be along soon to explain the balance of forces - but my A-level physics says the weight is mostly vertical hanging from the crank and spread by the crank pulling on the bracket and the wheels pushing on the wall. Unless you're mounting a downhill beast they work just fine.
If your wall is horizontal I would be worried?
Surly the space saving idea you would want it vertically? I.e flat against the wall :S
Lidl currently have a cable hoist thingy at the mo
Used to use Tusk hooks in a communal hall [url= http://www.tuskstore.com/index.php?cPath=22 ]Tusk[/url] - worked pretty well and have a place to lock to
I just use a pair of [url= http://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9796552&fh_view_size=6&fh_start_index=6&fh_eds=%3f&fh_location=%2f%2fcatalog01%2fen_GB%2fcategories%3c%7b10099%7d%2fspecificationsSpecificProductType%3dbrackets&fh_search=shelf+bracket&fh_refview=search&ts=1236355268823&isSearch=false ]B&Q shelf brackets[/url] with some pipe insulation on them to protect the paintwork.
Cheap and works.
I've got a couple of large 'hooks' from somewhere like B&Q to stick my bike on the wall in the shed. They are about a foot long with a bit of a kick up at the end I guess to stop anything sliding off. They are covered in soft blue plastic so the frame doesn't get scratched (alhtough it's totally knackered anyway). I have got one that goes just behind the headtube and the other sits where the chainstay part of the swingarm joins the shock link. The wheels fit on the remaining length of hook if I so wish to hang them too.
