Hammerschmidt Servi...
[Closed] Hammerschmidt Servicing without special tool
Has anyone serviced a Hammerschmidt without the special tool or used an alternative. Making louder than usual noises in overdrive and I'd like to take it apart but £140 for a tool seems a bit stiff and its such a simple job £60 at lbs seems a bit steep.
Any tips greatfully received..
Posted : 29/10/2012 11:34 am
[i]its such a simple job £60 at lbs seems a bit steep[/i]
I suspect they'll not be servicing many of those so need to get the tool paid for by those that they do?
Will you be servicing it more than 2.5 times?
Posted : 29/10/2012 11:41 am
Ive got a tool you can borrow for a small fee if you like. I paid quite a bit for it, but serviced my Hammerschmidt regularly.
You wont be able to do it without some sort of tool.
Posted : 29/10/2012 12:07 pm
Trimix, I'd happily pay a small rental fee. Did you find much wrong/needed servicing or did it just need a good clean and grease?
Heard the small cogs can wear?
Posted : 29/10/2012 2:21 pm
I should have asked whare are you based, roughly. I'm in the Leicester/Coventry/Birmingham triangle..
Posted : 29/10/2012 2:22 pm
Oxford / Banbury, not that far away if you want to pop down and borrow it.
Posted : 29/10/2012 2:33 pm
That sounds reet. I've good reason to nip down to Oxford/Banbury every now and then, either that or my mate can nip in. I'll email you to sort it out 🙂 Cheers loads.
Posted : 29/10/2012 5:26 pm
could try this, good general purpose tool for things that rattle and clunk, and its cheap
http://goo.gl/SsE1w
Posted : 29/10/2012 8:40 pm
