Would it work??
dunno but this is one interesting looking bike your thinking about.
perhaps in california, dunno about the UK's "wrong kind of mud"
but would it cost less/perform better than a Rohloff?
I think it would work, yes. Do we have a clue on Hammschidt cost yet?
****ing expensive is the official line 🙂
ah but the frame it's going on isn't costing a vast amount 🙂 Dialled Alpine + Specialized E150 fork + alfine + hammerschmidt = a fantabulous trail bike??
is an XT or X9 drivetrain that bad? hammerschmit seems to be a solution looking for a problem....
it'll work fine and yes you'll look a reet tit
*puts down calculator*
apparently the hammerschmidt comes with a 22 or 24T chainring and the overdrive will give you 1.6 over that, so either 36T or 38T equivalent.
The alfine can take a 18T or 20T.
at 20T the range is 15" to 76"
400%
a standard 22/32/42 chainset and 11:32 cassette will give you a range of
18" to 99"
450%
So in terms of gears it seems fine. I thought there might be a limit on the size of the chainring up front allowed (as in the smallest) but cant find anything on it.
I don't think I'd want an Alfine hub on a bike like an Alpine - if you're intending using the bike like it should, then I'm not sure the Alfine would take kindly to any sort of big drops or jumps. That's one of the reasons I'm rejiging my stable to include a conventionally-geared hardtail as well as my Alfine'd one.
[i]"Dialled Alpine + Specialized E150 fork + alfine + hammerschmidt = a fantabulous trail bike??"[/i]
I thought the E150 had **** all mud clearance?
A triple clamp fork on an alpine, that really would look gash
[i]"but would it cost less/perform better than a Rohloff?"[/i]
I thought the hammerschimdt had loads of inherent drag/friction?
I seem to recall (though probably wrong) seeing the hammerschmidt was going to be around the £500 mark. So plus an alfine is about the same as a rohloff? Probably weighs more than a Rohloff setup as well
It would use triggers front and rear instead of a twist grip though
and you need an iscg mount
Didn't Ash/sapaudia use an Alfine on his Alpine for guiding in the Alps? (say that quickly when you're pished!)
Hub gears can take plenty of stick- vanderham used a Rohloff til recently.
However, an Alfine weights 1600g, plus the weight of a hammerschmidt. A rohloff weights 1700g, as well as being about the same price as a hammerschmidt + alfine wheel build.
well... I already have an alfine and a spare E150 fork... just add in an Alpine frame and the Hammerschmidt and my bike is done...
of course, don't [i]really[/i] need the Hammerschmidt side of things, a single cog up front would be fine I'm sure 🙂
How about using 2 rings and a bash, with a shadow mech and a 9-speed cassette on the back?
why be conventional? 😉
Wouldn't you be cheaper just buying another bike for when that one gets a bit dirty>
I'll be honest mate, I ran an Evil Sovereign with a Rohloff for a while and I found that on this sort of bike, a hub gear adds too much weight. A hardcore hardtail is already pretty heavy- about 30lbs, and you add a hub gear and you have something that's a pain to drag up a hill- mine was 34.5lbs with a pretty trim build- Thomson, All Mountain SLs, 5.1 rims. I'd say go for normal gears on a hardcore hardtail.
