Halo SS hub fail...
[Closed] Halo SS hub fail...
So my Halo SS hubs failed last night on the commute home.
It lost all drive, I suspect that the pawl engagement ring that's pressed into the hub has 'let go' and is just spinning inside the hub, I'v not checked it yet, after pushing/freewheeling for 6 miles I couldn't be bothered last night.
Anyone had this happen with a Halo hub before?
If I'm going to replace it any suggestions for a robust SS disc braked hub?
Posted : 28/04/2015 10:29 am
Surly hub with an ENO freewheel. Sorted.
Posted : 28/04/2015 10:42 am
Beaten to it but was going to say standard answer is screw on hub of your choice (Surly, DMR, WI, Phil etc) and a WI ENO freewheel.
For a cheaper option than the WI freewheel have a look at the Halo Clickster, it's actually rather good, pickup is better than a standard WI (on par with the trials version), and comes in at about £45, not as serviceable as a WI though, but I've had a couple now and they've been reliable for thousands of miles with no issues at all.
Posted : 28/04/2015 10:46 am
I've a clickster as well - us it for more general riding. They are great. But, serviceability of the WI ones means I use it over the winter.
Posted : 28/04/2015 10:53 am
Depends on how pimp you want to go.
Mate's got one of these with the 10-mm RWS thru-axle conversion on his dirt jump bike, lovely bit of kit.
Of and it has a centre lock disc mount, it just just comes with a cover which is what you can see in the photo.
Posted : 28/04/2015 10:56 am
Seen this happen on a mates halo too - certain models the ratchet mechanism appears to be made of brie and is only about 1-2mm tall, so wears away in no time, leading to absolutely no drive.
As others have said, hub of your choosing and a WI ENO or Halo clickster freewheel is the way to go really.
Posted : 28/04/2015 10:58 am
I've got one of those 240 SS hubs up there as well ^
It is good, but depending how sensitive you are to pickup you might find it annoying without the ratchet upgrade!
Posted : 28/04/2015 11:10 am
Happened to my Halo too, they seem very sensitive to chain tension
Posted : 28/04/2015 11:36 am
I like the Clickster, used to run one on my SS CX. Decisions, decisions...
Posted : 28/04/2015 12:55 pm
