i've searched i promise (though im sure someone will find it now). however - can you get a connversion kit from 30mm hope BB to GXP? Is it a 30mm specific issue or possibly a Hope specific issue?
I've ordered a new set of Cranks for a new frame, aong with BB - it will be shiny Hope EVO. Cranks are yonks away, but BB is in stock. Brilliant. I've been loaned (ha, he'll never see them again) a set of SRAM XO1 GXP cranks that will go in place of my very tired SLX's from about 2004.
However, Hope to DUB = YES, HOPE to GXP seems no.
Alternative, i still have my old Wheels MFG HTII so could convert these as an interim step along with non rusted bearing's..
having just written that - shall i just replace the bearings in the BB shell on the old Wheels MFG to GXP compatible can you do that?
thanks
Sui.
Hope do a spacer that simply slots between the narrower axle side and the larger BB. I bought one when i mistakenly bought a shimano bb to replace a gxp one.
I dont think there is a hope 30 -> GXP converter
There is a Hope 24 (shimano) -> gxp converter.
The GXP is 24mm on the drive side 23 (ish?) on the NDS, so they do a 1mm spacer for their Shimano 24/24 BB NDS to reduce it and make it work
You would need to reduce the 30mm BB by 6&7mm to make it work.....
Just buy a cheap GXP BB. Won't be too much more and they only last a few months anyway......
Or better still, buy the convertor linked above and leave your Shimano SLX or whatever it is in. Keep the Hope for when the cranks arrive.
Cheers all! May just fix bearings and kit kit as suggested..
