Have a route on my Garmin Connect records that I'm riding next week.
Trying to get it to transfer from the PC to my Garmin 500. "Send to Device" didn't work.
Exporting it as a tcx file to the Courses or New Files folders didn't work.
Please point out my glaringly obvious oversight while I go and make tea and calm down
Thanks you
Usually it's a case of dropping the route in the "New Files" folder on the device then restarting it. I've had "fun" with transfers, not all .tcx or .gpx files seem to be accepted, I think it depends on the number of waypoints.
Think it's just having a hissy fit.
I'll try again another night.
Had another go at this tonight, and it's still not playing
If I save the .tcx file to the laptop and then drag it into the new files folder on the Garmin, I can see it on the Garmin drive. But when I unplug the Garmin and look in courses, there is nothing there. Plug the Garmin back in and there is no course on the drive.
Where does it go? Why won't it stay where I want it? Why am I about to cry with frustration? What should I replace it with?
Turn the Garmin off and on after you disconnect.
And as whitestone said - there's a maximum number of waypoints.
I have. Numerous times. ๐ฟ
Sod it. Drink beer
I don't know if I had the same issue, but it was certainly similar. I have a Garmin Touring. Had the same problem - couldn't load a route either through Connect or by gpx or tcx.
I did an update. Normally the last thing I'd try. Correct service is now resumed. Whether this'll work with a 500 I've no idea, worth a try?
I'll try it. After I've done the beer drinking bit......
Try clearing some space down on the unit by deleting old course or stuff you no longer need....
[quote=MoreCashThanDash ]Had another go at this tonight, and it's still not playing
Are you doing an "Eject" on that drive before removing the Garmin? It could be that Windows is caching it, in which case you need to do the Eject so that it clears the buffer. Then remove the Garmin when it says it's safe to remove.
Ah, ok, I'll try that as well
