greasing chainring ...
[Closed] greasing chainring bolts....
got a new blackspire stinger yesterday so like a giddy child with a new toy i went about fitting it last night....while the chainset was off i decided i might as well replace the chainrings, but i didnt put any grease on the threads of the chain ring bolts....
am i asking for trouble in the long run or can i get away with it?
Posted : 03/07/2013 10:38 am
I wouldn't put grease on chainring bolts, full stop. Loctite yes - grease no.
Posted : 03/07/2013 10:42 am
^^ this
Posted : 03/07/2013 10:51 am
good job i didnt put any grease on them then....the thought had crossed my mind...looks like i'll be taking it all apart again to add the threadlock....missus wont be happy!! ๐Ÿ˜›
Posted : 03/07/2013 12:52 pm
Why take it all apart? Just take the chainring bolts off...
Posted : 03/07/2013 1:06 pm
I grease them & I haven't died yet.
Posted : 03/07/2013 1:22 pm
I grease the outside of the outerbit, but not the threads, I've not be othered with threadlock on the threads tbh, seems fine.
Posted : 03/07/2013 1:23 pm
so i can get at the granny ring...it's a 2 ring and bash set up
Posted : 03/07/2013 1:37 pm
I copper grease mine
Posted : 03/07/2013 1:41 pm
Always grease threads on mine. Steel bolts innit.
Posted : 03/07/2013 1:47 pm
 DanW
As far as I recall Loctite is better in every bolt situation bar none you would be tempted to use grease with. Happy to be corrected though as I can't find the article ๐Ÿ˜€
Posted : 03/07/2013 3:11 pm
Always grease mine. Lube on a thread actually lets you tighten the bolt more. Never had a chain ring bolt come loose yet ๐Ÿ˜‰
Posted : 03/07/2013 4:10 pm
to grease or not to grease, that is the question.
Posted : 03/07/2013 4:16 pm
 Sui
i'm a greaser ๐Ÿ™‚
Posted : 03/07/2013 4:39 pm
 Sui
mind you I also grease every bolt I can find on my bike 0 no real reason other than a [i]probably[/i] bad habit.
Posted : 03/07/2013 4:40 pm
Dab of copper grease on the threads of mine, without then can be a pain to remove as they just rotate.
Posted : 03/07/2013 5:27 pm
True. If I was going to use a grease, I'd go copper-slip as you could argue it's an anti-seize, so doing what you'd want the grease to do. Grease is great for parts that move against one another, but an anti-seize is better for parts that don't.
Posted : 03/07/2013 5:28 pm
 JoeG
I usually use grease on mine. I have used blue Loctite in the past, but it can be a PITA to clean off, especially from the female threads!
I just put a bash on a 2 week old set of XTR cranks. I'd say that Shimano uses a threadlock on them at the factory; it took quite a bit of force to break them free! So I used the thin, green loctite (low strength for screws) when I reassembled them. We'll see how well it works.
Posted : 04/07/2013 2:56 am
I've seen more than one Shimano chainring bolt snap due to the stupid forces needed to break the threadlock that they use. I've never had a problem with using grease.
Posted : 04/07/2013 7:25 am
 DanW
Shimano factory bolts are over torqued- the threadlock used is pretty irrelevant.
Medium strength Loctite is best in almost all applications. It acts as an anti-seize as well as holding the torque originally applied to the bolt better than other options
Posted : 04/07/2013 9:33 am
As Unklehomered suggests, it's worth putting a film of grease/anti-seize on the outer section of the bolt. A failure to do this sometimes results in mysterious and hard-to-locate clicks.
Posted : 04/07/2013 10:33 am
..results in mysterious and hard-to-locate clicks.
Yep, that's why I'm a greaser - I have a deep hatred of my bike making any creaks or clicks and grease [i]seems[/i] to be the best way to avoid this.
Posted : 04/07/2013 10:41 am
 Yak
Loctite 243 (blue) for me.
Have used grease before when I had no loctite to hand and it resulted in bolts coming loose. This was on a single ring set up with the thinner single-ring specific bolts. Never had a double/triple come undone with grease or Loctite, but having had the single ring bolts come loose, I won't be using grease for any set-up.
Posted : 04/07/2013 11:40 am
